Fuel pressure issue
  • TWISTER
    • Jun 2010
    • 264
    Fuel pressure issue
    Fuel prssure is "jumping around" too much for my comfort. Let me supply you guys with all the info and see if anyone has a clue as to what is going on or can help me. I need to get this problem fixed!!!
    The fuel pressure at idle is 9lbs. It sits there just fine in the pits or shop dead on 9lbs. Once on the track under acceleration it bounces all around from 6-9lbs(as best as the driver can tell its in that area) and every now and then the light comes on, with a 4 lb sensor,at the very very end of the straightaway. I have changed everything in the fuel system except the fuel filter canister(allstar brand torpedo style) and the braided line coming from the fuel log to the gauge. I can't see where either of those would be my issue but they are gonna be changed next. In the mean time I have tried with and without a regulator.2 different gauges,3 pumps(10-11 lb pumps), 2 regulators, new fuel line twice, all new fittings,2 different barry wright fuel cells, and 2 different carbs. None of those changes has fixed my issue. And yes the filter is in properly. We have changed the element in it and even took it out with no difference. I keep hearing that the issue is on the suction side of the pump but I don't know what else to do. I have had the push lok style fitting and hose on there and now I have the braided reinforced line. Fuel cell vent has been changed twice as well. Oh yeah, we have had 2 different motors in the car as well so the fuel pump rod can be ruled out. There are no obvious fuel leaks anywhere on the car that we can find. All fittings are teflon taped where applicable and others are good and tight. We have pulled the spark plugs and looked at them and they seem to be fine. Nice brown look to them. The motor is running great and we dont seem to have any issues but we have never had the fuel pressure to jump around like this before.
    We are running all steel 362 limited motor.
    This problem started when we got our new car. All of the original components in these scenarios were ran and proven to be just fine on our old car. We only saw this issue when we started with the new car and it has done it since the first night out in the car. However since the issue, as i have already stated, all components have been replaced except that 1 line and fuel filter canister.
    ANY help on this would be appreciated!!!!
  • bigk44
    • Feb 2011
    • 67
    What about the pick up? Has it been checked/ replaced?
    • Brian Gray
      • Feb 2012
      • 1102
      Is the fuel filter near a heat source. Close to header. Engine. Ect?
      Shocks by BGR army
      • Brian Gray
        • Feb 2012
        • 1102
        Are you running a fuel return, what fuel pump.
        Shocks by BGR army
        • lazermod3
          • Jan 2008
          • 1910
          Call Bloomquist!
          you just got greased
          http://www.goddardwarrior.net
          • ric78
            • Feb 2013
            • 48
            Had a very similar issue earlier this year. If you are running a mechanical pump on the block check the pushrod length. Mine had worn, fuel pressure got real erratic change everything in the fuel system before I checked that.
            • Bubstr
              • 3734
              No real answer, but I'd look at fuel line size, bouncing fuel gauge and the possibility of needing a large fuel log or small tank up front for fuel reserve. Or sticking spring on return circuit or pressure regulator if you have one.
              Good guess is bouncing gauge or need reserve in the engine area, due to end of straight pressure loss.
              Pumps pump well when slowing for corner, not so well when inertia is keeping fuel in the rear under acceleration. I've had this problem drag racing but put huge fuel lines on circle track apps. Sometimes a large fuel log to feed the double pumper is all the reserve you need before the easier pumping you get in shut down and corner. good luck
              There is a difference between pressure and volume, if you don't have enough volume, your pressure drops.
              • FlatTire
                • 560
                What kind of pump? I'm assuming block mounted with those pressure settings. What kind of fuel? I never had very good luck running the edelbrock block mounted alky pumps. Always inconsistent fuel pressure.
                Are all your fuel lines secured and not kinking or sucking shut?
                Is the fuel tank vented? If it has a ball vent, is it installed properly?
                • TWISTER
                  • Jun 2010
                  • 264
                  I will try and answer everyones questions......
                  -Not only has the pick up been replaced, the whole fuel cell has been replaced.
                  -Fuel filter is approximately a foot from the header, but that is the exact same location it was on my other car where it worked perfectly fine.
                  -No fuel return and I have had 3 different CV2508 pumps on it. They are a 10-11 lb pump which i can adjust with the regulator and acheive the 11 lbs.. Has a holley regulator on it, and have tried 2 of those as well.
                  -The rod length will be checked but it has had the same problem on 2 different motors and these are the exact same motors that were in the old car and ran with no issues.
                  -Gauge is a mechanical quick car gauge. Gauge was brand new and is clean. Have used 2 different gauges with same problem.
                  -I am using #10 line from the tank to the pump and number 8 line from pump to carb which again is the exact same set up that was on the old car, and again with no issues. I have also replaced all this line, TWICE, with new fittings everytime. I have run this set up since I been racing and never had an issue.
                  I am going to try and vacuum test the system as much as possible to see if there is an air leak somewhere. As well as rebuilding my fuel pump to make sure that is at full capacity.
                  I am willing to try anything within reason guys, so please continue to help. Thanks for the suggestions. please, keep 'em coming. Thanks.
                  • TWISTER
                    • Jun 2010
                    • 264
                    CV products, gas, block mounted pump. Yes all lines are secure and there are no extreme bends or kinks. Yes fuel tank is vented. 2 different fuel cells have been used.
                    • TWISTER
                      • Jun 2010
                      • 264
                      I have been told that if you run a regulator that your fuel pressure should remain steady at your desired setting and not move around. However, if you remove the regulator that your fuel pressure is subject to drop a couple lbs when under hard acceleration. Just so im clear in my issue.......The fuel pressure is not dropping like a tire gauge when you are letting air out with a slow fall off, it is literally jumping around 9 to 6 to 8 to 7 to 5 to 9. Its giving the same action as a gauge does when all the gas has been drained out of the carb or fuel lines are empty and you crank the car back up and it has air in the line so it dances a bit before it levels out. Thats how the gauge is acting under acceleration on the track. That is what led me to look for an air leak and replace all fittings and lines. But to this point it has been wasted time and money because its no better.
                      • TWISTER
                        • Jun 2010
                        • 264
                        No alky. VP gas.
                        • LimitedLM06
                          • Jul 2013
                          • 66
                          I'm curious about the RPM's. You said at the end of the straight? Could the pump be floating?
                          • cjsracing
                            • 837
                            every time I have had this happen I changed both the fuel pump and the rod and it fixes it. I used to happen the first night of the race season and then I started replacing the pump and rod right before the season and haven't had it happen since. It doesn't take much wear on the rod to make it to short.
                            • LimitedLM06
                              • Jul 2013
                              • 66
