loose in
  • racingford
    • Feb 2011
    • 114
    loose in
    too loose in off throttle, looking to up the right rear spring, i currantly have 225 on left and 200 on right rear. my question is do i up it by 25 or 50 or just switch the currant springs. I dont have other spring going to have to buy a spring and only want to buy one.thanks
  • drtrkr244
    • 1024
    A 200 in rr is usually too soft for a dlm. You could swap the rear springs if you didn't want to buy one. It would make your car tighter in and off. A 225 in rr is usually the most common but some do prefer 250 also.
    • fox1162002
      • 131
      Most guys are on 200 lr and 225 or 250 rr
      • Garrettshurling
        • Aug 2010
        • 72
        If your only going to buy one, get a 250 for the RR.
        Owner/Blogger/Crash Test Dummy
        www.nextlevellatemodel.com
        • hpmaster
          • Aug 2009
          • 1088
          I would try swapping the springs side to side and see what the car feels like, I think that will tell you more for 0 dollars.
