Power steering issue
  • r2rocket
    • Jan 2009
    • 94
    About halfway thru my last race, steering wheel started getting harder to turn. I kept going to see if it got worse or cleared up but the pwr steering started going in and out (working and then not working). I've checked all the lines, all tight, I had the proper amount of fluid and there was no leak anywhere. I checked the suspension on each side to see if anything was in a bind but I cannot find anything. A friend of mine mentioned maybe the seals in the servo might be giving up. Any thoughts on that or something else is appreciated.
  • bigk44
    • Feb 2011
    • 67
    Replace the hose. I had the same problem and it was hose, it was sucking closed. Replaced the hose and problem went away.
