ct525 quartermaster bellsousing question
  • lake speed
    • Oct 2008
    • 134
    I have a quartermaster bellhousing. its the one that doesn't have the idler gear in it for the starter . does anyone know if quartermaster makes a flex plate/drive hub for a ct525? their customer service and website are very lacking.
  • Lizardracing
    • 839
    Block mounted starter?
    The CT525 is internal balanced so you don't need a QM specific one. Use the flexplate the engine came with and the standard drive hub for what ever transmission your using. The hub goes on on top of the flexplate.
    • Lizardracing
      • 839
      If you have the bell housing that has the reverse mount starter you need this and the correct starter.
