Excuse me if I am missing the point on stored energy of a solid axle and a gun drilled axle. When I went to school, over 45years ago, the stored torsional energy of a bar or tube had negligible differences. It was based off of bar diameter, and bar length.
If you lock one end of a Torsion bar and turn the other with a torque wrench, to a specific degree, then increase it to the net degree, you would have that value. If it seems much like a spring rate checker, your right. A torsion bar is nothing more that a straight spring, that would be dependent on diameter and length.
All this said, the axles ability to store energy would be based on diameter and length, not if it's hollow. Hollow would only have the durability effect, if all other things where equal.
If you where looking for this stored energy to overcome the slip angle tolerances of a tire, I believe you would have better luck, looking into tire sidewall composition, tire pressures and wheel width to overcome oscillation that comes with exceeding the tire slip angle. That is my thought on this.
As a after thought, reducing un-sprung weight would aid in oscillation control. Gun drilled axles would have some effect on this.
