We were wondering how much HP gain you might see in a 350Hp engine going from Muncie 3 speed and stock clutch to a direct drive type trans like a Bert? Also how much HP it takes to turn a Quickchange over a ford 9"? I have heard some one say a bert was like having 40 more HP but forgot where i heard that. Thanks for your time.
Hp gain going to Bert and loss through QC
Is it time for another moment of inertia thread?
I'm sure somebody has run these on a chassis dyno back to back but getting that info for free might be asking a lot.
I'd be particularly interested in seeing the difference between a first gen Bert and and a second gen Bert.
I didn't know their was a difference besides the output shaft? Good to know. That's in reference to the Bert Transmission
I think you're talking regular spline versus ball spline. But I'm referring to first gen versus second gen.Originally posted by 7uptruckracer View PostI didn't know their was a difference besides the output shaft? Good to know. That's in reference to the Bert Transmission
Both first gen and second gen come with both output shaft options.
The second gen has completely different internals, is 17 pounds lighter, and doesn't spin the counter shaft when in direct drive like the first gen does.
First gen to second gen is about 4 hp. It's within the tolerance of the chassis dyno. We do see a significant variance it the amount of time it takes to accelerate and decelerate though.
A qc vs a9" though there is on average 15 to 30 hp used up on the qc. And acceleration is better on the 9" but decel is advanced on th qc .
Now I'm taking this from a shop that did the tests so this is only what I've been told.
I do know the 7.25 clutch through a Muncie uses up a lot more power than the original Bert/brinnShocks by BGR army
I've had first and second gen while the length of the output shaft was the same I don't think they were splined the same length because the long slip yoke would bottom out on the splines
The second gen Bert has 2 options for tail shaft length on a slip yoke version as well as a ball spline option.Shocks by BGR army
Yes but honestly I don't think it will show a difference in lap times.
You will see however and huge increase in life of components and reliability. Truth though is the original Bert is still pretty darn bullit proof.Shocks by BGR army
They are claiming less rotating weight so that would have to result in some gain (less loss) at the rear wheels. Whether it is significant or not is a good question. But the way I'm looking at it is a hundredth here and a hundredth there eventually get you a tenth.
