Late model shop stands
  • Gasface25
    • Jun 2010
    • 47
    Does anyone have a layout on how to properly build a set of mobile shop stands? Width? Pipe used? What size casters? Thanks.
    If a fat girl falls in the forest and no one is there to see it, do the trees laugh?
    All aboard the Cleveland Steamer!
  • RacerX10
    • 571
    most of those casters have a weight rating, just divide 2300 by however many casters you are going to use, ie if you had 4 casters on a back stand and 4 on the front, that's 2300 / 8 = 287 lbs so get 300 pound casters like this :
    http://www.northerntool.com/shop/too...ct_12813_12813
    you'd be rated up to 3200 lbs with those 10 dollar casters
    • Lizardracing
      • 839
      I'd recommend the metal wheel castors. The softer materials can increase the resistance to roll and when it sits for a long time they can flat spot.
      • Kwoods25
        • Jul 2014
        • 455
        I would like to build a set also, they are very nice. You could go solid rubber tires as well
        • merc123
          • 1261
          I used polyurethane casters for mine. No issues with flat spots. I over-built the casters because when my head is on the line I don't want a the caster to fail. Mine were 750# each so each stand could support the entire weight of the car with ease, by itself. Another reason I went with these casters is they will stand up to anything on a shop floor (grease, oils, fuel, etc) without breaking down.
          Here are what mine look like: http://www.03sbgt.com/photos/race-car-stands/
          Web: http://www.t17.co
          • Kwoods25
            • Jul 2014
            • 455
            Originally posted by merc123 View Post
            I used polyurethane casters for mine. No issues with flat spots. I over-built the casters because when my head is on the line I don't want a the caster to fail. Mine were 750# each so each stand could support the entire weight of the car with ease, by itself. Another reason I went with these casters is they will stand up to anything on a shop floor (grease, oils, fuel, etc) without breaking down. Here are what mine look like: http://www.03sbgt.com/photos/race-car-stands/
            Thanks for the info, gonna build me a set
            • merc123
              • 1261
              I also want to add, accidentally, my front stands will sit angled in the frame of the rear stands so it makes them more compact.
