Integra refresh
  • keeks
    • Oct 2008
    • 687
    Integra refresh
    Well, I just bought my first set of double adjustable gas shocks. Integra canisters. I'd like to send them for a refresh/rebuild and get them valved for my smack chassis. Does anyone have any advice? Thoughts on reliable shock companies? And how much I should expect this is likely to cost.
    There is no damage, came off a running car.
    Thanks
  • FlatTire
    • 560
    • phenom08
      • 228
      $75 labor per shock is pretty standard few others do charge more, plus parts. So $400-500 would be in the ballpark.
        I like Jerry Link @ SHY. He is probably on the higher end, but he actually gives you dyno sheets and will work with you on making changes if you demonstrate some knowledge.
        • Rogue1
          • Dec 2014
          • 33
          Denny Fuller at CPD Racing Tools, you wont find a nicer guy to work with, he's good enough for Ryan Gustin so....
          It's always the cars fault
          • 7uptruckracer
            Kenny Smith at B&O or Trey at Hitman Suspension
            • Brian Gray
              • Feb 2012
              • 1102
              $35 per shock plus parts. we use roehrig and accuforce dyno's . you will get dyno sheets and support for tuning.
              for $500 per season you get unlimited dyno testing. customized tests and valve adjustments.
              513-519-7745
              Shocks by BGR army
              • lrnvlFan1w
                • Apr 2009
                • 58
                Accu-Force Dynos and Testers, Accu-Force Shock Dynos, Accu-Force Spring Checkers, Keith Berner Racing, Millersburg Ohio, Accu-Force, Dirt Late Models, Shock Dyno, Spring Checkers
                Can't beat Keith Berner and Accuforce.
                • jrkracing54
                  • 620
                  Kirk Loudy at Envy Suspension has done my stuff for a while now and I really like what he does. Great to work with. Gets it done in a timely manner. Probably not the cheapest but you get what you pay for when it comes to most things. John 1*
                  — Heraclitus
                  • rickhulson
                    • Oct 2014
                    • 21
                    bite rite in hanover pa. he's very knowledgeable on the mastersbilt cars with integras
                    • cyclone9
                      • Aug 2007
                      • 28
                      Mike at Warrior Chassis!
