Lift arm or pull bar?
  • Dirtmod13
    • Jan 2014
    • 245
    Working on setting up our new rocket and a friend said a pullbar gives more traction. Any one tried both? Results...
  • save the racers
    • May 2013
    • 271
    I've tried the rayburn style pull bar and lift arm on the same car.The pullbar gave good traction but had a very narrow sweet spot.The lift arm was easier to drive and tune and was what we stuck with.
      A pullbar gives quick, instant traction that fades more quickly than a liftbar. It typically makes it very difficult to accelerate and steer at the same time. I don't really see it being compatible with the current 4 link at many tracks.
      • DirtRacer9x
        • Jul 2014
        • 305
        Lift bar and tied down front end drives off way harder.
          Not really. Better corner speed makes it come off the corner. Pullbar car would win a drag race. Tied down 4 link won't go without lateral acceleration.
          • DirtRacer9x
            • Jul 2014
            • 305
            So you're telling me you're going to achieve more weight placed on the rear tires with a pull bar than a lift bar?...
              Quite possibly. Neither device attaches to the chassis in front of the center of gravity. The pullbar will raise the rear of the car more allowing for more front to rear weight transfer. In your example, tie down shocks on the front will kill weight transfer.
                MasterSbilt_Racer is correct. Ratcheting down the front end doesn't allow the weight transferred to the front on entry to transfer back to the rear on exit. Simple physics...the rear tires need more load to create forward bite. The ratcheted down front end deal works best on momentum race tracks where you don't need as much forward bite. You keep the car at an angle of attack that promotes aero. On a stop and go race track, that is a junk setup.
                A lift bar and a pull bar can both create mechanical loading of the rear tires but the reason you can get more "drive" out of a pull bar is because it can be moved further to the left. That's a bit of a problem for a lift bar which really can't be mounted any further to the left than the right side of the drive shaft.
                • drtrkr244
                  • 1024
                  Matt49, I saw a dlm in the late 80's, with a pullbar mounted to the left side of a quick change. It had a mount off of the left tube and used the 90/10 plate for the right mount. Yes, it was on the short side but the car had unreal drive. I have always wondered when someone was going to duplicate that on these current setups.
                    Since the LR behind setup, most cars have more traction than they know how to use. End up tight-in/loose-off if you know what I mean.
                    The pullbar makes it worse. JMO. I've never seen anyone do anything but struggle with a pullbar on a LR behind late model setup. It's way too much traction way too fast even in the slickest of conditions. You end up just chasing your tail...literally. JMO but I would avoid it.
                    • Dirtmod13
                      • Jan 2014
                      • 245
                      [QUOTE=A lift bar and a pull bar can both create mechanical loading of the rear tires but the reason you can get more "drive" out of a pull bar is because it can be moved further to the left. That's a bit of a problem for a lift bar which really can't be mounted any further to the left than the right side of the drive shaft.[/QUOTE]So on a shorter track would you run the pull bar and on bigger momentum tracks run the lift bar?
                      • DirtRacer9x
                        • Jul 2014
                        • 305
                        So had anyone seen a late model pull the front tires off the ground with a pull bar? If so if like to know because I don't know any that have. Lift bar I see it many times. Not saying this is fast but I'm trying to refer back to loading of the rear tires pull bar vs lift bar.
                        • Dirtmod13
                          • Jan 2014
                          • 245
                          Or is it shock package with light rebounds that allows the fronts to lift off the ground?I know with our drag cars a near zero rebound will let any old car lift the front wheels with a stout small block.
                          • Dirtmod13
                            • Jan 2014
                            • 245
                            Then what about moving shock/spring on lift arm closer to the rear to give it more leverage?
                            • DirtRacer9x
                              • Jul 2014
                              • 305
                              These are all heavy tie down cars as well doing this.
