When we ran dwarf cars there were adjusters on the control arms so you could adjust without taking the arm off and turning the heim. Do they make these for late models?
1 pc lower control arms
They are called a turnbuckle. You will also need a female rod end.
Give Ronnie Warman a call at WRP Racing Products 325-655-0700
The adjuster for caster on the RF of a one-piece lower is a joke. That is a rigid structure so there is no way you can shorten one side to provide caster without putting into a bind which is exactly what it does.
Adjust caster with slotted uppers and you'll be better off. This also will help maintain wheelbases/lead that was built into the car. JMO.
Matt49 I should have been more clear. I am looking to extend the bottom control arm 1" to move rf out. The chassis is a 2013 Rayburn and with the front end set up there is no way to add another mounting point. Rayburn does make a longer arm but I am looking for a way to use the one I have. Also there are no slots on the uppers they use heim joints
If you lengthen the main tube, you'd also need to lengthen the "strut rod" portion. If done, the end width of the two would be too much, which would require either bending the strut rod portion or living with a severe bind, as Matt49 was referring to. In the end, nothing beats the proper part (i.e. - The correct length control arm). Also, the slots on the upper control arm would be on the main shaft, so the entire arm can be moved forward or back.
