Fuel regulator?
  • RSS
    • Dec 2013
    • 128
    Fuel regulator?
    What is recomended for regulator for gas? Been told to get a dead head and no return?
  • UltimateRaceCars
    • Jan 2014
    • 116
    I use a Holley bypass regulator with a return line, I plug the idle bypass jet to keep the idle pressure up.
    www.UltimateRaceCars.com
    • RSS
      • Dec 2013
      • 128
      Is this a big secret?
      • collateralDamage
        • Jul 2010
        • 110
        use a bypass regulator with a return line. anything else is a compromise.
        • powerslide
          • 2696
          How can anyone suggest anything without knowing what kind of pump you have?
          • RSS
            • Dec 2013
            • 128
            Sorry, we run a Ron's pump piggy back off of dry sump pump.
            • hucktyson
              • 1903
              With a belt driven pump you use a bypass regulator with a return line. I'm sure gray will choke
              In any second with how he uses belt drives unregulated with no return like and he drills his main jet circuits out with a half inch bit and it's still not enough fuel for his 358
              • powerslide
                • 2696
                I have had good luck with a holley regulator with a jet for idle pressure and bypass popoff for wide open. Mine has a return line
                • Brian Gray
                  • Feb 2012
                  • 1102
                  Bypass with return on any system is my preferred method. Specifically I place the regulator after the carb on its way back to the cell. Some do it in front I jst feel it keeps most of the load near the bowls as well as a continuos flow of cooler fuel near the delivery system. Jmo
                  3 goals with your delivery. maintain a high volume of fuel while eliminating heat and air from the system. Pressure honestly is a secondary part with the exception of high pressure.
                  Shocks by BGR army
                  • hucktyson
                    • 1903
                    Gray are you trying to say some people run bypass regulators on the front with a return on the rear ???????? The only way to use a bypass and a return is behind the carb or else you wouldn't have pressure to the carb ...
                    • rakracing
                      • Dec 2014
                      • 218
                      the racepump system with there regulator is installed between the pump and the carb with a return to tank, the hilborn pump i run off the dry sump pump uses a bg regulator between pump and carb also with a return, both use a jet for idle pressure and a adjuster for top end limit
                      • Brian Gray
                        • Feb 2012
                        • 1102
                        ^^^^ yes some people run it between the pump and carb. Either way will get the pressure down.
                        Don't be mad Huck that yours is configured the gray way! Lol. You have more of my work on your car than you know. That's a fact.
                        Shocks by BGR army
                        • ric78
                          • Feb 2013
                          • 48
                          Right it does not matter, regulator between pump and carb or after carb. It is a closed system the regulator with or without a return will not regulate or return fuel until the regulated pressure is reached.
                          • keeks
                            • Oct 2008
                            • 687
                            Huck, I just recently saw a setup with the regulator between the two carb inlet lines. I just don't understand how that was gonna work properly, but I just kept quiet, which is not easy for me.
                            • hatchet
                              • Nov 2011
                              • 46
                              keeks did you just see that on dirtondirt slideshow . If so look where the supply line is coming from . The feed from the fuel pump .
