any reason NOT not run the bolt in underslung bar on the right side of a 2010 blue/gray rocket ?
Rocket bolt in inderslung
The bolt in left under rail is mainly a drop limiter. They sell a eccentric that clamps to it to limit drop. as far as stiffening the tail it doesn't really change that in my opinion I don't feel it fits snug enough to effect the chassis in that manner.
There are some advantages to running it though.Shocks by BGR army
Drop limiter . Please explain . You want the left axle tube to hit the under slung and stop the drop ? I use my limiter chain (drop limiter) to help make adjustments to the car per track conditions . Also if the shock stops the rear end drop . Damage will take the shock out over time .
So with the spring loaded deal, how do you know how much total travel you're getting? Is it the same on every turn of every lap? How far does that spring have to move until it coil binds? Does it have a progressive rate as it coil binds or does it go from 600 to dead stiff immediately?
Matt it depends on how you use it. I've tried it and the results in a nut shell. In the tack it's kinda cool while the car is rolled over as you gain traction it adds some steer . It softens the blow while getting back to the throttle.
We didn't change a lot of springs or really test it to maybe the extent because most the time it upset the car too much accelerating. Maybe a bump stop would be a better choice over a spring with more travel.Shocks by BGR army
When I tried to do that deal years ago. It put an oscillation in the lr that was a big problem.Originally posted by Matt49 View PostSo with the spring loaded deal, how do you know how much total travel you're getting? Is it the same on every turn of every lap? How far does that spring have to move until it coil binds? Does it have a progressive rate as it coil binds or does it go from 600 to dead stiff immediately?Modern Day Spec Wedge Racing
