I think I know the answer, but does the belt length matter on a rear mount oil pump? Have a Peterson r4 and I can't get a 600 belt to work. Too tight! I have a 632 belt here also. Should be fine....right?
Oil pump belt question
Use what ever length is required to install with the correct tension. Make (not a nice word)(not a nice word)(not a nice word)(not a nice word) sure that the pump is bolted tight and square to the bell housing. I had a guy tension the belt with the tensioner before the bolts were tight which resulted in the pump not tightening up flush and losing the belt at 8000rpm which cost about 8000 to fix ... The belts stretch after you run them also and after losing a belt like that and having a correctly tensioned belt break in the line up area I will only tighten a belt 1 additional time after the first install before I replace it.
