spindle jigs
  • HRT2332
    • Aug 2014
    • 38
    spindle jigs
    has anyone built there own spindle jig. I have alot of torn up spindles and i think it would be cheaper for me to fix all these instead of keep buying new ones. If no one cares to share how they built theirs so i can figure the best way to build one I would appreciate it. You can text me some good closeup pics or email. Thanks. 865-740-1917 or roberthuskey23@gmail.com
  • Brian Gray
    • Feb 2012
    • 1102
    easiest way i found.
    buy an allstar spindle checker kit.
    a steel lock ring and whatever bolt fits the steering arm
    steel plate and some tubing also misc hardware
    install the spindle pins. place bolts in the holes of the spindle checkerfrom bottom pointing upward, place a bolt in the steering arm. tighten all the hardware.
    place the spindle on a steel plat approx 1/4 " thick, with the lower balljoint bolt and steering arm bolt touching the surface. weld these to the plate.
    use the tubing to make an attachment between the upper ball joint bolt and the plate. weld in place
    install the hub nut on the snout.
    make a plate with 2 holes that will bolt to the lock ring . tighten the plate to the locking nut. weld a piece of tubing to the plate attached to the nut that will also be able to be welded to the base plate your spindle was placed on.
    make it as solid as possible. now you have a jig you can build and check your spindles with.
    Shocks by BGR army
    • HRT2332
      • Aug 2014
      • 38
      thanks for the reply that helps and also gives me some ideas.
