What ratio are most guys running with a triple pass radiator. Also who makes fan Schrouds for Late models? All I find are deep ones for streeters. Thanks
Pulleys snd Schroud?
Not many running triple pass radiators, most are double pass. I see both 20% and 30% pulleys being used, I think the 20% is better personally but either get the job done. Bernhiesel and Dominator both make shrouds.
I have had great results with a double pass and the 19" GM 4 blade fan without a shroud over the last 6 or 7 years. Also have been told by people that ran triple pass that their cars ran warmer than with a double pass. I have always ran the 20% reduction pulleys.
Some good reading on this and other related topics here:
For me pulley ratio is determined mostly by RPM of the engine as I try to keep water pump speed in the 7500 RPM range, so most engines will get 1 to 1 and the higher RPM ones will get 10% underdrive.
