brass filings in gear oil of Winters rear
  • LART
    • Mar 2010
    • 53
    Any ideas on where to check? Thanks
  • cumminsman08
    • Jan 2010
    • 71
    How many laps since its been last split apart/rebuilt? Take a magnet to these shavings and verify if you haven't already...
    • Brian Gray
      • Feb 2012
      • 1102
      Pretty sure the only brass would be the ring gear backer. Like above stated magnet to double check . Steel can get heated to a brass like color. Either way take it apart an look.
      Shocks by BGR army
      • hpmaster
        • Aug 2009
        • 1088
        The gear backer thrust button is the only brass I can think of in a Winters. To wear that you have other issues in the carrier bearing I would think. Pretty sure you need a complete tear down and overhaul.
          Or someone cranked it down during a bolt check! lol It has happened!
          • hpmaster
            • Aug 2009
            • 1088
            Yea I will give you that. LOL
            • drtrkr244
              • 1024
              Or the fittings for the vent and oil filler lines!
              • clayman2
                • 153
                a winters rear has nothing brass in it unless it has the low friction ball bearings on the spool or pinion I have seen the spacers for the balls break ,the side preload spacer is hardened steel in a winters, frankland has the non adjustable brass spacer on the side bell
                • racin6mod
                  • 2172
                  I just pulled the tubes out of an older winters qc and it had a brass backing plate. who know if it was oem or a replacement.
