What is a good indication of to much stagger?
to much stagger
Tailed out, excessive stagger induced camber wear on the RR. I don't normally have to go over 5" I look for another change
In certain situations we have ran as much as 7 inches, but with the soft right front set ups were running now, and the amount of rear steer were getting from this, were down to half or less the stagger we use to run. also like 7up said , unless your on a cambered rear end , you will have camber wear on the right and left rear tire.
You have to be careful with stagger to sometimes flat trace tracks will do the opposite with large amounts of stagger if you go in with 4" and then switch to 5-6-7 inches if you don't account for other things going on. What problems are you having you're on a Black Front End Rocket aren't you?
