Limited late - z link option
  • Dirtmod13
    • Jan 2014
    • 245
    Ran 3 practice sessions with the clamped in front of the left rear. Car was really fast. Track owner took away the option to use clamped up. Now Only 2 options are bolted to birdcage ( so it rotates away from the spring in the corner) or z-link. Now i can see how the z- link would rotate into the spring just like a clamped up setup, but is a z- worth trying? Another car there had it and he looked to be quicker than the others. Does anyone still use this setup? What spring?
  • 2old4this
    • Jan 2014
    • 137
    Call cj rayburn he will talk to you no matter what car you have.
    • Bcollins82
      • Jul 2009
      • 322
      They won't let you put it on the forward arm and run it on swingarm?
      • save the racers
        • May 2013
        • 271
        We ran a z-link with spring on the swing arm car .It was easy to set up and adjust, had a wide sweet spot.Best i remember had a 400 r/s spring,500 l/s with at least 150lbs of bite.
        • Dirtmod13
          • Jan 2014
          • 245
          Yeah, rule is 4 link or zlink only. Coil over must attach to birdcage. No clamp.Must be mounted in front of axle on left rear. Everything else is open. But we have a shock rule so no adjustable or re-valved shocks. Installed zlink tonight and cycled it through. Doesn't rotate a whole lot into spring. But definetly more than the 4 link with spring attached ahead of axle on birdcage on LR. Tried soft spring to get some preload and have spring rate on LR at full drop but even at 125# it has a couple inches of gap between spring and top of coil over cup/ mount. 225# had 4" of gap.
            Need really long trailing arm.
            • Dirtmod13
              • Jan 2014
              • 245
              Top / rear , used the longest bar we could find. Wondering about indexing birdcage a little bit differently, wonder if that'll get the wrap into the spring. Wondering about that for the 4 link also. Since its mandated to be in front- it indexes away from the spring. But maybe indexing and maybe moving one or the other closer/ further from the normal mount on points where bars bolt to birdcage we could lessen that negative effect.
                The old Rayburn geometry with 32" trailing arm works pretty well for your application.
                You could move the lower link closer to the axle and get a lot of angle in it. 20 degrees at least
                • save the racers
                  • May 2013
                  • 271
                  We added the longer rear bars the second year.The car was very quick on the little bull rings.We could get it to hike the l/r up high if we wanted.It was never any faster like that.
                  • Dirtmod13
                    • Jan 2014
                    • 245
                    Update. First race, first ever feature win in Usra limited late model class. I appreciate all the help and discussion/ ideas all of you have given to my posts and others as well.I think it was possible only because of things you guys have posted and taking the time to help us guys out. Thank you.
                      Nice of you to let us know. Congrats!
                      • TheJet-09
                        • Jul 2013
                        • 1616
                        Congrats on your win! Now your competitors are going to be looking at what you're doing.
                        • Dirtmod13
                          • Jan 2014
                          • 245
                          Right?! So we need to cover the rear end because what we did is so simple if they see it they'll duplicate it. What is the rear cover called and where do u get them. Some are printed.
                          • Punisher88
                            • Nov 2014
                            • 495
                            Modern Images can make them for you and if you get him to do your wrap he can even print them to line up with your wrap and match it when on the car. Tell him Russ Ogletree sent you if you contact him.(706) 681-4665
                            • Punisher88
                              • Nov 2014
                              • 495
                              Kind of interested in clamping the left rear like was discussed earlier? Is there a specific bracket you buy to do this and do you remove the traction shock and just clamp the shock with the spring in front of the axle to wrap into the spring when under throttle? Thanks for any info.
