Just taking a poll of sorts. What pad and compound are most people on front and rear. I have my own opinion but I think this is an underlooked area. Might be good to take a fresh look. Are yall running split compounds. Also include if your running split master cylinders or even master cylinders!
Brake Pads
Dtc 30 here too. But I'm not even close yet on the setup. They seem to be consistant thoughShocks by BGR army
Are the 70's too aggressive? I was thinking about keeping even master cylinders, 30 fronts and 70 rears. I'm a trailbraker. Or it it not worth killing rotors?
Yeah I know just thinking. Well it seems like most are on Hawk which is actually kinda surprising because we have gotten away from them on asphalt. Just using this to get some more opinions. I personally like Hawk pads. How often are doing maintenance on your pads and rotors and what are you doing?
I used Hawk 70's on my old C5 Corvette for road course racing. Very aggressive pads but they stop great. The downside was that I usually cracked a rotor about every weekend running them (each weekend we ran 2 45 minute races typically). Just to give you an idea how they worked, but they would last all race long with no brake pedal loss.
I don't know if late models produce as much heat as what I did, but I ran cooling ducts to them on the fronts and still had problems cracking rotors at least on the fronts.
