Stroke on lift bar shock??
  • 17m fan
    • Aug 2007
    • 388
    02 black front rocket, steel block/heads. I've got a couple of the the recommended 7/3 shock valving but curious to know what the stroke is supposed to be on the lift bar. Are there any advantages to running a shorter or longer?
  • Brian Gray
    • Feb 2012
    • 1102
    7 in is plenty. 7/3 is std valve but do know that those numbers vary in real world between mfg .
    For instance a 7/3 from Afco is not the same profile if you had integra build you a 7/3. Accuforce has a nice build for a 5th coil on the cheap for a black front.
    Shocks by BGR army
    • Brian Gray
      • Feb 2012
      • 1102
      as far as advantages disadvantages . Keep in mind you can only allow the axel to wrap or unwrap so far before you snap the u joints off.
      Shocks by BGR army
      • 17m fan
        • Aug 2007
        • 388
        Thanks a bunch. I've got a Afco 1373 T7 that i'll throw on there and try it.
