left rear birdcage
  • jsw444
    • Apr 2008
    • 68
    left rear birdcage
    what effect would moving left bottom bar down on birdcage and chassis equal????same angle same length just moving bar farther from axle tube and lower and chassis equal...
    It has less influence on steer and thrust loading.
    • jsw444
      • Apr 2008
      • 68
      thank you.....looking for more drive without affecting balance.....not sure this change will do that but we will give it a shot....thanks again
      • jsw444
        • Apr 2008
        • 68
        tried this change.....driver hated it car was extremely loose.......gonna try something different next week.....thanks for the help.....
          Did you make sure it kept birdcage clocked the same so you didn't lose wedge on scales?
            • 2020
            As MasterSbilt pointed out, you most likely added static steer to the car and reduced the static LR bite if you just moved the bar down without rechecking anything. Since the LRL bar was moved down on the cage (the farther you moved it the more off it will be) the raduised holes in the frame will now be off and basically pull the bottom of the cage forward adding static steer and lose static LR bite.
            • jsw444
              • Apr 2008
              • 68
              thanks guys..thats exactly what happened.....lost bite .......so if im understanding this right when we lower bar on cage we need to change length of bars to get birdcage back to beginning so the bite remains the same???? thanks again
                Adjust your bottom bar to regain weight. Then all should be OK.
                • jsw444
                  • Apr 2008
                  • 68
                  sweet...thanks ...... let you know if we try it again....thanks again.......
