Winch battery
  • Wheelman33
    • Apr 2008
    • 232
    Winch battery
    What kind of battery are you guys using on your winches? And how often do you charge them?
  • TheJet-09
    • Jul 2013
    • 1616
    I've just been using an off the shelf 12v which I charge every weekend. I've been meaning to wire a 12v supply from my truck so it charges while going down the road...just been too lazy. I am, however, going to put in the Optima deep cycle I used to have in my car to see if it performs any better.
      Optima Red Top date coded 1995. Used to be a race car battery.
      • 06Tireman
        • Apr 2013
        • 163
        There was a 16 volt Turbo Start in our trailer when we bought it.. Wanna talk about pulling a car into a trailer in a hurry.. WOW..
        • AmickRacing
          • 236
          I've got a regular deep cycle battery in my trailer, got a decent cheapie charger that charges anytime I have 120v to the trailer.
          When I was using Dad's trailer we had a couple yellow optima batteries (old ones from the car), we charged them probably once a month, or when it'd barely pull the car into the trailer (aka when we'd forget).
          Home Page
          http://www.AmickRacing.com
            We're pretty anal about charging batteries so it is on a 2 amp charge all day/night at the race track while the generator is running. Then all day Sunday at home while cleaning and usually unplug it Monday morning or Monday evening when I get home from work. Nothing worse than the winch quitting on you when you're trying to load up. First-world problems I guess :-)
            • grt74
              • Jul 2009
              • 1380
              thats what we use but MAKE SURE YOU CHARGE IT,if you let it go dead and put the charger on it and try to pull the car in it will kill the batt,but we only charged it every 3-4 weeks
              • stock car driver
                • 3233
                optima same size as race car so you have a spare if needed
                charges with the truck going down the road and charges whenever the generator is running via a charger that's plugged into the trailer wall and wired to the trailer battery.
                • 06Tireman
                  • Apr 2013
                  • 163
                  We throw the charger on it every 2 weeks while at the track for a few hours.. Actually prefer it to not be fully charged..
                  • centralpa43
                    • May 2014
                    • 43
                    we run an Optima in the trailer that came out of the car from last year. if for whatever reason the one in the car goes bad we have a backup. also we run a battery tender on it from the time the car is unloaded until it's reloaded.
                    • ledfootproducts
                      • Aug 2014
                      • 688
                      Standard Walmart car battery with a very small trickle charger connected at all times. The trickle charger comes on with the generator. Been running for 3 years.
                      Follow us!
                      • SRXSRULE
                        • Jan 2011
                        • 217
                        optima was a great battery at one time, Now they have more failures then standard premium batteries. I had great results with Napa Legend batteries. Same battery in the trailer and race car, trailer battery charges anytime the truck is running and you never have to hook up a charger. Eric
