sidebite question
  • taylor2727
    • May 2013
    • 203
    sidebite question
    I have a generic question without regard to individual setups. What does everyone think the most effective adjustment to get more side bite into car while at the track . Jbar,right side bars, moving lead etc. Thanks for ur input
    J-bar down on pinion
    • cjsracing
      • 837
      For me personally it is moving the Jbar down on the pinion or shortening the Jbar.
      • JustAddDirt
        • 1893
        scotch
        I agree with this
        • tin man
          • Nov 2007
          • 28
          raising weight up on the frame
          • 25drtrkr
            • May 2015
            • 856
            lowering right bottom bar, lowering j-bar on pinion, stiffening lf spring
            • grt74
              • Jul 2009
              • 1380
              springs and weight placement
                Boys, keep in mind that the O.P. is asking about changes to make AT the race track. Moving weight is a pain the a$s and changing springs gets strange unless you gotta a smasher. I think we can almost all agree that the quickest way to find side bite at the race track is with j-bar. That being said, you can get your car too tight in a real big hurry. Been there, done that, and unfortunately continue to do that :-0
                • grt74
                  • Jul 2009
                  • 1380
                  10-4,thats what i get for not reading or just skimming through,springs are still pretty quick but make sure to do it on the scales and write down all of the rounds,we almost never move the j-bar anymore,unless we go to hard tires
                    • 14306
                    I don't consider a spring change all that tough. I don't seem to have much issue.
                    • taylor2727
                      • May 2013
                      • 203
                      Thanks guys so by a poll it looks like a jbar change is the quickest change at the track for sidebite gain another question would b have u guys ever tried raising both pinion and frame or lowering both at Same Time ( just wondering can pinion b too low and causing car to roll to quick and lose bite . Where raising both sides might help ) thanks ur awesome
                      • PushinTheLimit
                        • Apr 2013
                        • 465
                        As long as you keep the same ride heights when you change springs, shouldn't be that hard I wouldn't think. I've done that at the track a couple of times... maybe not as quick as a J-bar adjustment, but still can be done fairly quick. I also agree with the j-bar down on the pinion for more sidebite.
                        • 25drtrkr
                          • May 2015
                          • 856
                          I agree with you Matt about moving lead. But I wonder if we're not crutching the setup with j-bar/rear steer adjs. Mark Bush made a comment recently in DLM about the necessity to change %'s when track conditions warrant them. I think I'm going to put the car on scales and figure out where to move lead, and quit being LAZY!
                            I don't disagree. Mark Bush is one of the best. Personally I think moving weight UP as the track gets slicker may be a better adjustment. Then your percentages are the same but you're promoting weight transfer without mechanically altering the car.
                            Or...get the weight where your car works best in the slick and the use the "crutches" to help free the car up early on when it's tacky.
                            • PushinTheLimit
                              • Apr 2013
                              • 465
                              Matt, that's kinda where I'm at with mine (weight moved while on the scales). I feel like my slick setup is decent, but I've always been too tight when it's tacky. I've been trying move bars and change springs only to get where it needs to be free enough early in the night. Still not there yet, but getting closer I think.
