Originally posted by MBR Performance
View Post
Mastersbilt Chassis?
And I have seen main rails and uprights off the main rails that were like tin foil when cut up.... or wrecked, how do you know? I have personally seen garage kept, externally ascetically beautiful cars that were 8 years old crack at the rf kick up from internal corrosion. I don't believe the main rail ends were closed in the old days either as I recall. Good luck!
Theres a machine called a sonic tester that tell you the wall thickness. Im pretty sure Nascar still uses them.Originally posted by CCHIEF View PostAnd I have seen main rails and uprights off the main rails that were like tin foil when cut up.... or wrecked, how do you know? I have personally seen garage kept, externally ascetically beautiful cars that were 8 years old crack at the rf kick up from internal corrosion. I don't believe the main rail ends were closed in the old days either as I recall. Good luck!
It appears to me, Krooser has made very professional repairs in his pics. If he selects the appropriate safety devices, I don't think he will have a problem. I applaud his effort to get back on the track!Turn LEFT, Vote RIGHT!
Thought you guys would like a sample photo of the Ruggles scales I bought this week... should be into them for about $75.00 total. Thank God the "Safety Nazis" haven't taken over the specs on weights and measures!Attached FilesMember of the Luxemburg Speedway Hall of Fame
Class of 2019
