Billet,,, I've run the 400/200 stack a lot on my grt even used it with the lock ring at 0 travel, any idea how that compares to the 16" barrel spring on a rocket, tighter ,looser , in middle and off
16" 150 barrel spring
To be honest anymore, I hate the LR spring. It's so driver or situation sensitive, you can't really give a general rule of thumb to it.Originally posted by rakracing View PostBillet,,, I've run the 400/200 stack a lot on my grt even used it with the lock ring at 0 travel, any idea how that compares to the 16" barrel spring on a rocket, tighter ,looser , in middle and off
Case and point, I've softened/stiffened the LR spring on several drivers at different times and gotten different reactions a few months later, lol.
Just this last week one guy got a different reaction then he has in the past. Then on one of the other drivers I did the exact opposite as far as changing rate and he felt the same thing. Both got a tightening effect but from completely different directions on spring rates.
Personally, I ain't been a fan of the soft stuff for years now and typically don't recommend anything softer then a 225 for the most part. Not that is correct by any means, just seems like the stiffer stuff works better with my type of set-up or what ever.
Spring rate is spring rate so really don't matter whether it's a single spring or a stacked spring (assuming no stop nut or coil binding to change rate thru travel). Now granted some might be more linear then others.
For the most part, you will notice changes on entry or upon initial throttle and not so much off the corner with a LR spring change. However many will feel a change off corner, but you can argue that most of this comes from a change in the middle. Mess up the middle and most feel it all the way off the corner but most of the change IMO is from the middle handling changes.
Take that for what it's worth (nothing) and you get what you payed for that info, lol.
Thanks for clearing that up, billet! I did the same thing with the same driver but different car. He said it helped the drive on a Smack but hurt the drive on a blue Rocket. I chalked it up to a finicky driver! LOLLions don't worry about the opinions of sheep.
That's what I would typically expect, like I said more times then not it's about entry and initial throttle. Entry change is usually the same for most, it's the middle where the confusion comes in. More often then not, the different changes (tighten or loosen) to the middle is directly related to the change in entry, IMO.Originally posted by phenom08 View PostTried it this past weekend. It seemed to tighten up entry and maybe the center just a little, but gained no forward bite over a std 200
