Originally posted by rakracing
View Post
Lift Bar location on Rear-end
Makes no difference and found no advantage are two totally different answers... Lol Many people have tried a left mounted lift arm, but as you said, the forward upper mount is very important, and it puts that mount too far left. And that usually means the LF is in the sky, and the car won't turn in a 40 acre field. But it absolutely makes a difference moving the rearend mount left to right. The GRT arm you speak of, is that the one that had no side brace and had 4 mounting points, 2 right and 2 left?
its been a few years since I looked, thought it attached to the left only but I might be wrong, I understand what your all saying, I myself thought it would help drive off on the slick ,I have run lift bar between the brackets and 2" out on the right and didn't feel a difference, never tried full left.
Let me try to explain this more clearly, so we all understand the different points of view whether you agree or disagree.
From the lower 5th coil theory (lower 5th coil mounting point and a line 90 degree back to rear end is loading point):
I used to disagree with this as I wasn't looking at it correctly and argued about this and had MasterSbilt_Racer's view on it. I was looking at it from a view that the rotation is following the angle of the torque arm and not 90 degree's to the rear end. Picture the T/A mount in the normal position and say it's half way between the tires if the arm where to run straight forward then half the weight goes to each tire. Now say the torque arm runs at a 45 degree angle towards the RF and the 5th coil bottom is mounted so its 75% towards the RR vs the LR. The argument is that when the T/A lifts it is trying to twist the rear end clockwise (looking from the back of car) thus moving the loading point to that 75% of the way to the RR which is in line with the lower 5th coil mount, which leads to application of the theory in the post of racer2e.
While I understand that theory and feel it SHOULD be correct, I have not found it to work that way for what ever reason. Whether I'm wrong and got some misdiagnosed feel from the multiple drivers during multiple private tests, I don't know but all came to the same conclusion multiple times so sort of hard to discount that. So until I see otherwise I stick to my original conclusion that it makes a difference.
A person could also argue that a pull-bar, how many modified guys move the pull-bar only on the rear end and swear they can tell a difference without moving the front end??? If that theory is correct it should apply somewhat to a pull-bar also. While there are differences, it should be causing some of the same twisting (rotation on the rear end from the rear view) that a torque arm is doing and thus effect it similarly as a T/A.
I know of 2 guys (one modified and one late model) that I made parts/torque arms for that mounted between the bells of the Q/C instead of the right side so they could move it left to right just like a pull-bar. While I’m not aware that they ever did any private test sessions and adjusted it then (without the track changing so you get decent info from the change), but they swear it makes a difference, this could be further confirmation of my findings also if you want to use their race day finding as good info. I’m suspect of any non private session testing info and take it with a grain of salt as it isn’t always reliable but then again so can testing info as it’s subject to interpretation.
Also many times when I moved the TA left or right, I didn’t readjust the side link to the frame. So if I moved it right on the rear end, the end of the torque arm swung a little the opposite direction due to the side link usually mounted more to the middle of the arm. So that means if I moved the TA right at the rear end (too loosen on throttle) then I swung the lower 5th coil mount left. So if the lower 5th coil position/90 degree line is the load point, then I moved it the opposite way (towards the left thus tightening on throttle by increasing the load on LR) so if anything I should have gotten a the opposite reaction but didn't according to the drivers. However I can't say I have ever moved it more then 2" so my info could not be a clear as it might be with moving it farther to get a bigger reaction.
The GRT torque arm I think he was referring to was one that mounted to the left side of the bell and zig/zagged to the right and mounted the 5th coil in the standard location, but I believe they also later on came out with one that had 4 rod ends and mounted to both sides at the same time but still zig/zagged with standard 5th coil mounting. I was referring to the left side bell mounted one that I was told wouldn’t turn in a 40 acre field. I never heard of anyone trying the dual mounted one to comment on.
Billet (confused and shrugs even more), LOL
Remember my opinions are worth what you paid for it, NOTHING (Grin)
The debate continues.....
pullbar makes more difference left to right because of the spring closer to rearend and more to the left makes a difference..rayburn had a far left bracket also....ahhhh anyone remember the old fiberglass crossover lift bars back in the day,the driveshaft through the lift bar, or am i the oldest one here..L.O.L. ..windy..~V~..
it maters only because of the changes that occur during acceleration and deceleration. for explanation reasons forget about the rotational loading just for this explanation.
lets use extreme examples. if you mounted the liftbar on the axle at the furthest point to the left say near the birdcage. during acceleration while the car rises on the lr how does this effect the movement of the 5th coil mounting point on the bar vs if the lift bar were to be mounted at the extreme right hand side.
it will change the location of the effective plane and you will have a varying degree of change depending on a multitude of things such as bar lengths , amount of indexing, and if the lift bar is stablized by the rear end or a side link.
moving the bar mounts left to right will have an effect on what path of movement the lifting point takes and visaversa for the 6th coil .
even with that said, in my opinion moving it along the plane of the center section is not enough to make a noticable difference in the dynamic .
hope this simplifies this for you.Shocks by BGR army
