caliper sticking
  • ace1
    • Oct 2007
    • 205
    caliper sticking
    I have rebuilt the master cylinder and replaced the rf braided hose last summer. I haven't ran the car since. I was going over things this week and the rf caliper is sticking. I took the caliper apart and it looks good. What will make it stick. I can't figure it out unless I still have air in it. LF is fine so I don't see its the mc
  • rakracing
    • Dec 2014
    • 218
    if it has a cross over tube like a superlite caliper, replace or cleanout the tube have had them clog and hold pressure on the outside, also check for a dented line if using steel
      Air shouldn't cause your issue.
      May be something you've already checked but if you have 3-way brake shut-off, it could be a faulty unit or incorrectly installed.
      • ace1
        • Oct 2007
        • 205
        I didn't check the cross over tube when I had it apart. But it seems the inside is the side not releasing. It has a ball valve for a shut off. I can squeeze it just slightly with a pair of pliars on the inside pad and caliper body and it turns fine.
        The rotor is pretty rough on the inside. I just haven't replaced it. Could the pistons be getting turned just enough it won't release good?
          Haven't experienced that but I can see where if you've got some strange wear and the piston is not running "square" to the cylinder, you could certainly be having an issue there with it binding.
