Dry sump issue?
  • DoubleD
    • Aug 2007
    • 101
    Dry sump issue?
    I have a 5 stage Peterson pump. Just recently started having a low pressure issue. When the engine is cold it runs around 45psi. At full throttle when warm it's around 80. After I race around 15 laps after the engine hAs some heat in it the pressure drops to around 10 psi during cautions or end of race. Any ideas?
  • JustAddDirt
    • 1893
    bypass valve poppet sticking?
    • fast_crew
      • 844
      If problem just arrived sounds like a main bearing or cam bearing issue...or the pressure section of the pump is worn or damaged from debris..exe: rocker arm or lifter needle bearings..etc..
      Josh K.
      • SLM98
        • Sep 2009
        • 407
        Whats the pulley size on pump, 40 tooth?
        • DoubleD
          • Aug 2007
          • 101
          40 tooth pulley on the pump. Oberg looks good. Is it anything to be overly concerned with? Makes me nervous when the oil light comes on
          • powerslide
            • 2696
            Sounds like its starting to get some wear or like mentioned the pump isn't keeping up and might be damaged slightly. how many laps/races are on the motor? What are the oil temps?
            • AmickRacing
              • 236
              Is the idle set approximately the same? A few hundred more RPM will likely change the pressure a fair bit....
              Home Page
              http://www.AmickRacing.com
