Having to shim flywheel
  • steelkiwi75
    • 366
    tried two different starters and wouldn't engauge. Was told i need to shim the flywheel. My question is, how do I know how much to shim it?
  • hucktyson
    • 1903
    The majority of the time the problem is that fitting next to the starter not being pumped full of grease
    • powerslide
      • 2696
      what kind of bell do you have?
      have you tried to pry the idler gear forward to see if it will engage?
      • GRT62
        • Jan 2014
        • 177
        Had a similar issue few years ago pumped it full grease problem solved
        • toloud
          • Sep 2012
          • 24
          flywheel shim
          Brinn says .040" to .070" between idler and flywheel. The information is in the tech section of the brinn website .
            • 2020
            Often over looked and most are too far away without some shims but will work decent with a new starter and clean or lubed idler.
            I have found that using a dry lubricant will work much better then grease or WD-40 as it gets gritty really fast and will cause the idler to hang up. Try some dry graphite or similar dry lube instead.
            • Mad Jack
              • 25
              Plus make sure you are using the same brand Flywheel as the Bell Housing they do not enter change very well and going to ruin flywheel.
              • powerslide
                • 2696
                this is what i was trying to get out of him.
                • steelkiwi75
                  • 366
                  Both are berts but will try grease and lube. I had a modified toyota starter on it for my crate motor and it engages fine but not strong enough for my steel block limited motor.
                  • ledfootproducts
                    • Aug 2014
                    • 688
                    Warped bell housing did it for me. Got a new one and did not need any shims after that.
                    Follow us!
