Track conditions and bite
  • mark1971
    • 224
    In general, when track is wet and tacky do you need more or less bite compared to a dry slick track? Thanks.
    Assuming you're talking about LR bite...
    More is "generally" better in slick conditions. YMMV. Adding LR bite (static cross weight) will typically loosen entry and tighten exit. But as tracks slow down you don't always need as much side bite because entry speed is down. So more LR could help you all the way around. It depends on track configuration and how the driver puts the car into the corner.
    • DEKconsulting
      • Apr 2015
      • 234
      Ask any driver when they want the most traction in the mud or the slick. The answer should be in the mud . Ask this by mark richards and i thought id be slick but wrong we more traction to turn the car in the mud
      • DEKconsulting
        • Apr 2015
        • 234
        I did some testing on a quarter mile bull ring fast and muddy with 70 lbs lr and 170 lbs lr back to back nothing else different. The car turned so much better in an thru the middle
          • 14303
          You always want a balanced car. Sure, you can stab and steer in the mud. It takes traction to do that.
          Ideally, we would keep the same yaw in the car on slick and tacky. We would make adjustments to keep the car attitude the same and it will drive the same.
          • PushinTheLimit
            • Apr 2013
            • 465
            DEK, which bite setup turned better for you? It wasn't clear to me in your reply.
            • LateModel B23
              • Oct 2012
              • 283
              Won a lot of late model races @ Devils Bowl with 80# or RR bite.
              • DEKconsulting
                • Apr 2015
                • 234
                170 lr was the better one but toned it down to about 145 to be more balanced
                • PushinTheLimit
                  • Apr 2013
                  • 465
                  What is interesting to me is that adding LR bite loosens entry and tightens exit... but you typically add wedge to the car when the track slicks off to tighten it up. Seems like that contradicts each other. Or am I just thinking about it wrong?
                    • 14303
                    You might be surprised what is "typical" these days.
                      It's difficult to add LR bite without changing other things.
                      Example: If you add bite by giving the LR a few turns, you've just increased j-bar angle and left side bar angles.
                      • 25drtrkr
                        • May 2015
                        • 856
                        I don't know about the rest of you, but adding wedge in LR never gave my drivers enough drive or side bite in the slick. Generally, I adjusted RS bars and jbar and sometimes 5th coil.
                        • DEKconsulting
                          • Apr 2015
                          • 234
                          We find a number that works for us and leave it alone tacky or slick
                          • W2racing
                            • Dec 2010
                            • 53
                            Ok I'm confused. I don't know crap about suspension.But I always thought that adding lr bite would tighten car on entry and exit. Not doubting u, but how does adding bite loosen entry?
                              • 2019
                              Think the shopping cart theory, push the cart straight and stop the LR wheel: it goes left
                              More LR bite is more static weight on LR tire then RR, so more weight on LR should mean it has more traction then before thus when on the brakes or the engine is slowing the car the LR drags the car left more.
                              Pretty crude explaination but gets the point across, lol.
