GRT Mount Locations
  • luv2pla
    • 224
    GRT Mount Locations
    On a 2003-era GRT, what is the distance from the center of they lower control arm to the strut rod mounting point at the front of the car? It appears to be around 20-1/2" but because of the "tweaking" It's not exactly obvious.
    • 2019
    It's not really important front to back, but side to side is..... It should be in line with the lower control arm bolt. If it's off it will add caster gain or loss.
    • luv2pla
      • 224
      I'm planning on going back with the one piece lower control arm and there is very little adjustment with that so I need to be at least close.
        • 2019
        I thought about the one piece lowers right after I posted and thought that might be the reason you wanted it, my bad.
        I don't have a measurement that is probably any more accurate then what you coming up with so I'm no help.
        • luv2pla
          • 224
          Let's try this instead. Does anyone have a one piece GRT right front lower control arm that they can measure the distance from center to center of the heims?
          • rakracing
            • Dec 2014
            • 218
            I have 21-1/2 center to center from hiem to hiem , 18"hiem to center of ball joint and 27" center of hiem to center of balljoint that from the one on the car that hasn't been altered by the wall, if you no what I mean.
            • luv2pla
              • 224
              That's exactly what I needed. Thanks very much!
