What will be the big chassis adjustments from switching from an aluminum block to a steel block? I know the rear percentage will change probably but any major changes.
Switching from Aluminum Block to Steel Block
Joe's Race Parts
From Mild to Wild...
and Everything in Between
http://www.191speedway.com
http://www.joesraceparts.comTags: None
Back to one of my pet peeves again:
Engine placement is based of COG of the engine so saying steel block needs to be raised while most of the time is true, it depends on the engine. If you simply swap out blocks with the same internals then yes the COD was lowered in the new steel block engine and likely needs moved up. But if you have different internals like 2 completely different combo's the weight of the crank and rods and rest of it come into play. You can have a aluminum engine and steel engine that have the same COG hieght and therefore require the same mounting height.
in short: COG and overall total weight of the engine determines mounting height not whether it's steel or alum block/heads.Last edited by billetbirdcage; 09-01-2015, 01:53 PM.
To put some numbers with that, some of my alum. /steel motors are within 30lbs ,some over 100lbs.With the heavier motors it seems to loose forward bite.The driver lives on bread and water during the season so we have some ballast to move up.
