rear wheel hop on exit
  • Steveh3500
    • Sep 2014
    • 2
    Can anyone explain what would cause a rear wheel hop on exit when i run the very bottom but not when i run a higher line, i run a 3/4 scale late model with a cradle rear end rr has bilstein 3535 with 95lb spring lr has bilstein 3030 with 105lb spring, car handles great but would love to run bottom without having to let up due to all the bouncing
    • 2020
    If you have a spring or rubber bushing on the limiter chain, that will/can cause it.
    My bad Edit: cradle rear end as in a independent rear suspension? Common issue with those.
