Pinion Mount Question
  • LateModel B23
    • Oct 2012
    • 283
    Came across a pinion mount that is different from the ones I usually use or have. The "spacer" that goes behind the J-Bar has a small set screw in it and the part itself does not notch into the plate like the others I have.
    Edit: I found it. It is the Allstar.
    Anyone use one?
  • powerslide
    • 2696
    I think wehrs sells something similar they call it a climber mount. Haven't heard anyone complaining about them but I haven't ever used one.
    This is it right? http://www.jegs.com/i/Allstar-Perfor...60288/10002/-1
    • LateModel B23
      • Oct 2012
      • 283
      The one I have is the 60268 double sided.
      • 25drtrkr
        • May 2015
        • 856
        The set screw is to keep the climber part from moving. Some use it , some don't. Just make sure its real tight and it wont move.
        Lions don't worry about the opinions of sheep.
