Are their noticable horsepower gains depending on what carb. spacer you use? What do most of you guys use? What size engine and/or carb.?
Carb Spacers
I don't think I've ever saw a 1'' spacer loose power.Every motor is different and you need to try that stuff on the dyno.If I couldn't dyno I would put a1'' open on it and read the plugs.
With brodix spec heads the edelbrock 2925 was better than the hvh.A ported hvh made it carry the hp longer after peak.
