What size tires and wheels are ran. Does a late model run wider tires and wheels on the right side. A smaller tire and wheels on a LR. And smaller on LF like the go karts do or is everything the same size all the way around?
beginer question about tires & wheels
The norm is a 15x14 wheel 5in. offset on all for corners. Tires will vary on driver preference, but most builder recommend 1/2" to 1" front stagger ( RF bigger) and 4-5" of rear stagger (RR bigger). Your RR tire will be the biggest usually marked 29 or 92 depending the tire type. There are several different size combination you can run tire size wise, but that is the basics. Hope it was some help
bigger sidewall makes a little more forgiving in the slick.
at least that is what I seem to remember.
also a bit more ground clearance for cross member and frame railI think there should be lifeguards in the genepool.
The cross block pattern which is what u are referring to (I think) is only available in a 28.5 size from Hoosier. Not sure about American Racer. Go to Hoosier.com for lots of info.Member of the Luxemburg Speedway Hall of Fame
Class of 2019
Typically for that kind of rule, I just run a Hoosier 1600 or D55... I think the American Racer equivalent would be an AR56.
