rebuild rack?
  • mod88s
    • 226
    rebuild rack?
    What does it cost to send a rack in to have freshened? Mine is leaking a bit.
  • zeroracing
    • 1014
    I sent my sweet in before last year. It ran me about $300+ shipping, I thought it was in good shape when I sent it in. It looked brand new when I got it back. Since then I have been told by other racers they are fairly simple and the manufacture may replace items that are still good but don't look new.
    I had another brand that was leaking and grinding so I sent it in, they called and said it would be cheaper for new so I junked it and went to sweet.
      This has been my experience also. They are going to replace almost every seal and leakable/wearable part in the thing as a matter of preventative maintenance. But I'm personally okay with that.
      I was always taught to put things back together in better shape than you took them apart. It's amazing the things that you fix that you didn't even know were broken...or about to be.
      • RacerX10
        • 571
        I sent one in to sweet a few years ago, only cost me about $150.00 if I remember correctly. Guess it depends on what they are replacing.
        • popkorn42
          • May 2008
          • 67
          If it`s brt or appleton you can send it to Out-Pace . They rebuild them,
          • r2rocket
            • Jan 2009
            • 94
            I sent mine to Sweet in Kalamazoo last winter and they replaced all the seals and stuff on the inside trying to find a problem with a "catch" in my steering, costs me around 180 + shipping but it did fix the problem.
            • Dirtmod13
              • Jan 2014
              • 245
              mine was feeling like a bent wheel when doing pace laps this year, I read somewhere that it was either the pump or the rack. Anyone have this happen?Also I have 2 run of the mill el cheapo pumps, no way to tell what the numbers are, is there a certain size orifice/pump pressure etc that works best with the sweet racks?
              • save the racers
                • May 2013
                • 271
                Might try adjusting the preload on the rack.
