Leaking rack question
  • mod88s
    • 226
    Have a sweet rack. Leaking between the integrated servo and the adapter cup. I can grab the lines going into the servo and the whole thing swivels/loose. How do i tighten it up? the little allen bolts going into the adapter cup are tight, do i go in from the back side where the pinion bearing retainer is and tighten the nut on the pinion bearing?
  • Punisher88
    • Nov 2014
    • 495
    I recently had the same issue with mine. I figured that most likely a seal had gone bad and since it had been a few years since it had been serviced I sent it back to sweet and had it fixed there. Don't recall the price though.
    • rakracing
      • Dec 2014
      • 218
      the servo floats behind the screws and retainer ring, if its leaking its the servo probably the lower seal.
      • Kwoods25
        • Jul 2014
        • 455
        On every rack I have had the servos always swivel, but I have never had no leaks.
        • mod88s
          • 226
          Do they sell parts like seals so i can do it myself?
          • Kwoods25
            • Jul 2014
            • 455
            Yeah you can get the parts. Call sweet they are very nice people to talk too. And will help you out
