Rocket radius rod questions
  • keeks
    • Oct 2008
    • 687
    How much drop are you getting?
    • Kromulous
      • 3008
      I dont see it being any different really. As long as you have some sorta control over it.
      Overrail cars were all the rage, now its underrail. I think its all just marketing and hype in the end, chassis company's are in business to sell chassis so...
      I preferr the chain, a swivel device, and an over rail car.
      Just say no...
      • Kromulous
        • 3008
        Oh, and those brackets in the top pic are Rockets. I updated an 05 with that set up, at least the bottom bracket is, the additional piece btw. The top piece / bracket i believe is from another year car, older.
        The bottom bracket allows you to run a long bar lower, works good on big tracks.
        Just say no...
        • RacerX10
          • 571
          Assuming I measured correctly, 13 1/2" drop (top of axle to bottom of tube)
          • RacerX10
            • 571
            There's nothing in the Rocket setup book about running a longer lower bar .. how big of a track would you need to try out that longer lower bar ? 1/2 mile ?
            • Kromulous
              • 3008
              We tried it at Florence (Ky), not bad.
              I would think it would be good at Eldora etc.
              At the time we had a 99 Rocket, i updated it to these brackets, same ones you posted pics of. We were way under powered etc, but that car worked better than the 05 black front end car by a long shot. We were convinced it was possessed by some demons or something.
              He said several times, wish we would of kept that 99 car.
              As for set ups and books, that's all out of fashion by today's set ups. You would have to find an old Rocket book, i will see if we still have one.
              Just say no...
              • Ruhlman Race Cars
                • Oct 2007
                • 285
                RacerX10,
                The brackets on the car in the picture are referred to as Rocket 2 brackets. you'll notice the 2 small holes under the word Rocket on them that designates them as Rocket 2's. They have the holes on the radius of the older 5/8 hole brackets. We sell an updated upper shortener bracket that has the holes on the correct spacing and radius so the birdcage is not rotated when moving your upper rod.
                Feel free to give us a call if you have any questions.
                Brian Ruhlman
                Ruhlman Race Cars, LLC
                2132 Jefferson Road
                Clarklake, MI 49234
                517-529-4661
                www.brianruhlmanracing.com
                email: brianruhlmanracing@yahoo.com
                • RacerX10
                  • 571
                  Originally posted by Ruhlman Race Cars View Post
                  RacerX10,
                  Thanks for the info. It's a bit odd, because the Rocket set-up manual says a̶n̶y̶t̶h̶i̶n̶g̶ most made after 2008 should have a "Rocket 1" mount.
                  • steveshawjr
                    • Jan 2008
                    • 430
                    Not trying to high jack a post but it falls under the same thing ... I have a old rocket chassis (97) just starting out in late models and thes are my lower mounts and upper what would be the starting points on thes
                    62 mini mod
                    • RacerX10
                      • 571
                      "Cars prior to November 2001 (Identifiable with 1 single long slot cut in bracket between upper rod adjustment holes and lower rod adjustment holes)
                      - Scale top rods in 2nd (middle) hole / race top rods in 3rd (top) hole
                      - Scale bottom rods in 2nd hole up, counting from bottom
                      - Left bottom bar race position ins 3rd hole up from bottom
                      - Right bottom bar race position is 2nd hole up from bottom
                      • steveshawjr
                        • Jan 2008
                        • 430
                        Also this is a leaf/4 bar combo car so it don't have standard 4 bar brakets
                        62 mini mod
                        • RacerX10
                          • 571
                          Doesn't give anybody much to go on if the brackets aren't from rocket. Yours look like something added after it left the rocket factory.
                          • Kromulous
                            • 3008
                            Those old cars had 2 piece brackets like that, we had a 99, similar. Cut them out and put new style ones in there.
                            Just say no...
