What are your go-to adjustments at the track ?
  • RacerX10
    • 571
    I've been out of it for a while, looking to start racing again this summer. Everything is different then what it was last time I was racing a lot.
    Just curious what everybody's most common adjustments are at the track ?
    Seems like people talk about the Left Rear Upper radius rod a lot, and of course right front spring rate adjustments.
    Also, do you make bar / spring / radius rod changes, or shock changes ? Maybe both ?
    If you don't mind sharing, I'd love to hear what you change at the track, and why you change it.
    Thanks !!
  • 7uptruckracer
    Bite, Tilt, Front Rebound, RF Compression, and RS Bar Length, RR Spring for sidebite. All minor tweaks but that is it.
    • RacerX10
      • 571
      No bar angle changes ?
      • 7uptruckracer
        Not as much as we use to. Take good notes track to track. If you go to a quarter mile bullring then a 1/2 mile sweeper then probably. Same track nope. You're mostly accounting for travel changes as the track slows down and doing small things to change a little weight transfer and taking some dynamic rear steer out with the RS Bar Length. These newer cars utilize the front so much more then they use to so keeping them sealed off is key. You don't have to do as much in the rear to get them to turn like you use to. This is just my opinion get as many as you can and think through what we all say and decide for your own what you want to test.
          7up is giving very good advise here.
          • PushinTheLimit
            • Apr 2013
            • 465
            Small changes, I make rebound and compression changes, minor rear bar changes, and play with the bite. Bigger changes I'll change a spring rate or j-bar or weights. Pretty rare that I move weights... once I found what the car likes with my driving style, I really don't change much during the night.
            • phenom08
              • 228
              Lr wheel spacer, shock adjustment,
              • King1
                • Jan 2012
                • 354
                rear end lead, rr spring, stack lock out nut or bump stop height (whichever one you run)
                • RacerX10
                  • 571
                  What does "keeping them sealed off" mean ?
                  Thanks for your comments !
                  • RacerX10
                    • 571
                    Had a slight laugh about this. Isn't anybody NOT running a stack or bump stop these days ? I got the impression it was terribly complicated to get the setup right running either.
                    • 7uptruckracer
                      Aerodynamic nose all the way across as close to the track without hitting and right side skirts all the way to the ground as close as it can get without hitting. Sealed to the track. Keeps air from getting under the car and creating lift. This is why they have body deck drop rules now, fender rake rules roof rake rules filler panel rules etc aero is king lol
                        People who hope to separate you from your cash will tell you that it is terribly difficult. They will tell you that it is impossible to race without a spring smasher.
                        • TheJet-09
                          • Jul 2013
                          • 1616
                          @RacerX10, I was in your position three years ago..hadn't raced in over ten years and a lot had changed when I decided to try it again. At first I messed with the RF spring often but it just screwed me up worse in the end. You'll probably do just fine with a 350# or 325# on the RF. Any bar adjustments for me are typically RR lower (entry) and LR upper (exit). Maybe lowering the J-Bar on the pinion side a little (about 1/2") for the feature. Shock adjustments for me are just the recommendations from the manufacturer/shock guy. Your biggest obstacle will probably be knocking the rust off your driving skills. From what I saw of the pictures you posted in another thread, looks like you found a nice car. We need more people coming back to racing...too many are leaving. Good luck!
                          • 7uptruckracer
                            The smashers are nice though but nothing you can't do in the shop using some extra work and time, but time is money to the big guys i don't have the money so i just spend the extra time lol
                              They are putting a lot of importance on one data point on the track.
