Valence Height?
  • Punisher88
    • Nov 2014
    • 495
    Cove base would work well for what your thinking I believe. We used to use it on our kart noses to lower them a bit. Plus it has a nice contour at the bottom that lips out.
    • riddle28
      • Apr 2010
      • 1088
      ive got a question about valences. i dont run one now because i have an open trailer and its already hard enough to load as it is. i thought about getting one and taking it on and off at the track once its off the trailer. i race at a little 1/4 mile bullring, is there enough advantage there to mess with it?
      • lindsey97
        • Mar 2011
        • 84
        I have the same trouble getting mine in an enclosed with the valence. I jacked up the left front measured the distance between the shock bolts and made me a piece of 2 in x 1/4 in flat stock drilled 5/8 hole at that measurement. I used longer bolts and jack the car up and slide the flat on to hold the nose up level to load.
        • riddle28
          • Apr 2010
          • 1088
          i like that idea i may build something to go in between the frame and lower a frame to keep it raised enough. kinda like a fork saver for a dirt bike
          • a25rjr
            • 3774
            We bought a used Rocket roller a couple years ago. The owner had taken 1" tubing, flattened the ends in a press, and drilled 1/2" holes in it, and bolted them in place of the shocks. The lengths were for ride height but you could make them any length you want! I eventually took it a step further and made the lenghths correspond to the cars attitude on the track.
            Turn LEFT, Vote RIGHT!
            • TheJet-09
              • Jul 2013
              • 1616
              I was thinking about the different ideas for creating height when trailering your car. I, personally, would be hesitant to do anything that rendered the suspension "solid" while towing the car, most certainly between the frame and lower control arm. I know we strap them down pretty good anyway, but my concern is that we put far more miles on our car towing them to the track than we ever will on the track. Obviously clearance on the RF shouldn't be an issue. I've seen guys take old rear main bearings, jack up the LF, then put the bearing around the LF shock between the spring and adjuster nut. You can wire tie it in place to keep it there. That'd buy you an extra 2" or so.
                • 2020
                Easiest thing to do is have a set of bars or cheap old junk shocks/coil-overs to put on the car for hauling, it amazes me guys like to wear out or just put more time on their high dollar shocks going down the road. I mean what wears them out more 1 to 6 hours of bouncing while going down the road or the 50 to 75 laps you put on the car a night. Things to think about.
                That way you can just raise or alter which ever ride hieght on whatever corner with the set of bars or old coil-overs so it makes loading easier. I know some guys add rounds to a corner or corners, but I hate this cause next thing you know someone forgot to put it back some night cause they was in a hurry or thought the other guy did it, lol. I prefer to keep it simple and save the wear on the shocks by just switching them out.
                • Krooser
                  • Nov 2012
                  • 3117
                  Back in the leaf spring days lots of guys either blocked up the frame with the weight off of the springs while towing or had a swing down "jack" that kept the springs from working while towing. They secured the chassis to the trailer.
                  Class of 2019
                  • RCJ
                    • Nov 2007
                    • 509
                    I had a piece cut to fit between the lower a arm and the frame.Over time it did bend the lower a arm.Now I remove it after the car is loaded.
                    • RacerX10
                      • 571
                      Odd .. am I the only person that tows with the car strapped down over the chassis ? I go over the cross member up front and back down the the D ring in the floor, and over the rear clip in the back and down to the D ring in the floor. Doesn't allow for much shock movement when traveling, but there probably is a wee bit just in the give/take in the tie down strap.
                        • 2020
                        That's the most typical way and nothing wrong with it, I'm just saying the car still moves up and down working the shock and causing normal wear. Don't think it bounces much? How often does the car move side to side or shift in the trailer a little?
                        That's the reason in a perfect world, I'd use some junk coil overs to haul the car around. Sure it's more work to swap the coil-overs around to and from the track, but least your not adding wear on you shocks going down the road.
                        You could always argue, how much is this really wearing the shock? I can't answer that truthfully, may be so small it don't matter or maybe you send shocks off so often it won't matter either, just something to think about as many guys have some old twin tube or semi junk stuff around to just set up some with some old unused springs.
