Holding 100lb on front brakes
  • 17m fan
    • Aug 2007
    • 388
    Over the winter I put new seals in the calipers and added a bias gauge. And my fronts are holding 100lbs constant and zero rear with no pedal pressure. Bled the system manually and confident of no air. Balance bar even side to side and front to back. Even went as far as remove the pushrod and it's still at 100. Pressure on front is exactly 100 over rear no matter how hard you mash the pedal. Any suggestions?
  • Kwoods25
    • Jul 2014
    • 455
    RF shutoff?
    • 17m fan
      • Aug 2007
      • 388
      Makes no difference if RF is off or on
      • Kwoods25
        • Jul 2014
        • 455
        If you take line off back of gauge does it drop to 0
        • rakracing
          • Dec 2014
          • 218
          I chased a issue with handling for two months because of a bad front master cylinder holding pressure as the race went on rear tires would just spin no drive in car caused by pushing half locked brakes
          • 17m fan
            • Aug 2007
            • 388
            I want to say that yes the gauge goes zero when unplugged but I will check again to be sure. What do I look for one way or the other.
            • Kwoods25
              • Jul 2014
              • 455
              Could be a collapsed line, or a sticking caliper if you ask me
              • AmickRacing
                • 236
                What kind of gauge is it?
                Somewhat apples or oranges, but I had some fuel pressure issues, that turned out to be the gauge. If you pulled up on the line a bit, I could get up to 8 psi, push down, and it'd go to zero. It was frustrating, but after taking the friggen regulator off half a dozen times, and checking all the lines, tank, etc, it was nice to know it was an easy problem
                Home Page
                http://www.AmickRacing.com
                • 17m fan
                  • Aug 2007
                  • 388
                  Quickcar gauges
                    Can you spin the front wheels at all with the car on jack stands? If you can, that's a bad gauge. If it isn't a bad gauge, I would be VERY careful removing the brake line anywhere that you truly believe there is that much pressure in it.
                    • 17m fan
                      • Aug 2007
                      • 388
                      Both fronts spin however not so freely as without a caliper..the right front has more drag than the left but has surface rust on the rotor so I would assume that is part of the not so free spin problem.
                      • Lizardracing
                        • 839
                        100psi of brake fluid pressure would make the wheel very difficult to turn if not near impossible without a great deal of effort.
                        Figure this out will be simple.
                        Get in the car and push the brake peddle as hard as you can a few times. Get about 300/400 psi on the gauges.
                        Get out of the car and see if the tires turn. If they do, then you have a gauge problem. If they don't, loosen the bleeder screw at the caliper on the offending wheel. If the wheel/tire now turns free, you have a brake line, caliper or master cylinder problem.
                        • Kromulous
                          • 3008
                          Make sure the caliper is centered on the rotors.
                          I found this to be a problem on alot of spindles, you usually need spacers. These calipers are 4 pistons, so both sides need room to float.
                          Krom.
                          Just say no...
                          • Bubstr
                            • 3734
                            I had a problem similar way back. A new master cylinder wouldn't bleed back. The holes was in a wrong spot on a brand new one. A wrong length rod can do something similar. The piston has to come to a neutral position to bleed off pressure.
                            • JDracing57
                              • Apr 2008
                              • 59
                              brakes dragging
                              I had this problem with my rear brakes once and it was because the balance bar in the brake pedal was bent.
