Bump Stop Help
  • RacerX10
    • 571
    Bump Stop Help
    So I've gotten a 300# spring and a 2" afco christmas tree bump stop to put on the RF of my blue / gray rocket.
    Is there more to mounting the bump stop than sticking it on the shaft and moving on ? Does it just ride on the lock nut / spring cup , or is there something that's supposed to go below the bump stop itself to ride on ?
    If I'm getting in to any crazy secrets, feel free to PM and thanks a bunch for any help.
  • fastford
    • 4059
    I ran mine strait on the spring seat on the bottom and a aluminum washer with a bronze bushing on top. my washer came from RE suspension , but I think afco has them now..
    • RacerX10
      • 571
      Thanks for the reply .. what's the bronze bushing and the washer for ? Seems like the shock would just compress straight down to the top of the bump stop.
      Also, how do you determine what the height of the bump stop should be .. or is that part of the magic ?
      • 7uptruckracer
        Take COT bump, get peanut butter, fill with peanut butter, give to your dog as a new Kong toy....problem solved..... It's best to use in a cup set cup on top of machine washer and using a washer on top of COT bump and use packers to adjust but in all honestly throw it away to progressive
        • RacerX10
          • 571
          Hrm .. just came across this .. is this how everybody does it ?
          • 7uptruckracer
            Yes is what I just described
            • RacerX10
              • 571
              I haven't driven in a few years. I don't expect to get on the perfect solution right out of the box here.
              I don't think I have enough laps under me yet to 'feel' what's going on with a stacked-spring / lockout setup. I've never been on a bump setup before; my plan is to run this for a bit just to get a feeling of how it works, since it's fairly cheap to do, then move on to something bigger and better later.
              Thanks !
              • RCJ
                • Nov 2007
                • 509
                Some shocks (bilsteins) use a circular clip to hold the shock rod guide in.The bump stop can shove the guide in to the shock body.They make special caps that set against the body to prevent this.Make sure you won't have this problem with what ever brand of shock you are using.I use a plain spring seat on the bottom. I just get one that does not have the slot cut in it to slide over the shaft.You remove the shock heim to install it.We had better luck not trying to over think the bumpstop.Just make a change ,try it ,then just say" ok that is what it does".
                • RacerX10
                  • 571
                  Thanks RCJ, that's kinda my plan. Try and and see what it does.
                  I have Integra IDA shocks. I'll take a look at the end and make sure nothing terrible is going to happen at the bottom of the shock when it hits the bump.
                  • fastford
                    • 4059
                    another very informative post from you , I guess my problem was the peanut butter, thanks for sharing your vast knowledge....lol
                      Have you had your RF shock valving setup specifically for running on a bump stop?
                      • 7uptruckracer
                        Ok here is the informative part. Most COT bumps are very progressive. MAKE SURE you have an external travel indicator. So you know how much you are traveling, so you can determine wheel load. If you travel a medium 3" tall COT bump 1" its about 150# of wheel load if you travel an extra .5" for 1.5 total its 350. So in a very short distance it spikes tremendously.....A lot have gone to the lockout stack or a bump spring because a spring is linear by design. So once it engages determining load itsn't hard to figure out. Bumps especially a COT bump is very hard to run on dirt because you aren't on a smooth surface. You also have to be valved properly with rebound and bleed so it comes off the bump at the correct time and you have to rebound to control the additional load. Also the height of the bump and how much shock shaft you have before you engage it is critical. Know how much your ideal travel would be without the bump so you know how much you want to engage it. The Bump Cup you posted lets the bump expand and load more consistently and also helps wear being it can't expand but so far outward before it hits the bump cup. The washer on top of the cone gives it a consistent surface to bump against and the packers or shims help control engagement height. So like I said Fill it with peanut butter and get something that is going to give you consistent results with your program. You can't just throw a bump onto a spring without doing all the math to know what you are changing and where. If you have a particular goal in mind post it and post your setup and posters on here will be more then happy to help you work it out. Remember aero is big these days as well as camber thrust.
                        • RacerX10
                          • 571
                          I haven't had anything specific like that done to the shock. I bought it (them) used as a set. What's special about the valving for a Integra IDA on a bump stop ? Again, keep in mind I'm running to "make the show" .. I'm not trying to light the world on fire yet. Will I even be able to notice any difference in a shock valved for a bump ?
                          Sure hope that doesn't sound contrary .. just trying to learn something
                          • RacerX10
                            • 571
                            Thanks 7up. If it really is that complicated, then I need to set it aside and go back to a standard 375 spring on the right front. I doubt I have the manpower or willpower to get all that right.
                            • fastford
                              • 4059
                              I agree with 7up, you cant just throw it own and expect miracles, BUT, on a smooth , slick track, with the properly valved shock, it is bad fast. I no longer use the bump stop because of rough track conditions , im on a two stage set up now that uses two springs that jerry link at afco set up for me. its easier on equipment when it hits the high side. also you will notice a huge difference with a properly vaved shock that has a lot of slow speed ( shaft speed) rebound.
