We have been fighting a ill handling race car for the 1st couple races of the year and i wanted to ask if you have the LF droop travel limited to much will it make the car loose in and thru the middle?
We are fighting a loose entry / middle and not enough drive off, not matter what i change. He says the car wont firm up and go, its like he has to wait on it. Once it does get on the straight it goes but it he looses to much speed in the corner.
Also the car is shredding the rear tires, more so than usual.
Pretty much standard 4 bar set up, 225RR, 200 / 165 LR, 100lbs bite. 500 LF, 350 RF high rebound. 5th coil is 36" out with a 350lb spring and no preload.
Thanks for any help, Krom.
