2 blade fan
  • Towers21
    • Oct 2012
    • 63
    2 blade fan
    Anyone running the Hendren fan, or any luck removing 2 of the 4 blades off of a 32* fan without balancing? Thanks
  • RCJ
    • Nov 2007
    • 509
    I cut 2 blades off my 4 blade .No problems, works good on cold nights.
    • Kwoods25
      • Jul 2014
      • 455
      A guy I know runs one that he cut 2 blades off of. He had heating issues after that. Went and bought hendrens fan and still had heating issues I run the Joe's 3 blade it works good
      • Towers21
        • Oct 2012
        • 63
        We're either of the applications using a shroud or just tucked up to the radiator? As for the Joe's, I have first hand proof of high rpm the blades flexing to " more " pitch and eating up a radiator. Glad it worked out for you though kwoods25
        • ric78
          • Feb 2013
          • 48
          We just cut 2 blades off an allstar fan works nice. We do go back to the four blade GM when it starts getting hot because the 2 blade flirts with running hot. I am talking around end of july/august hot.I have thought about cutting 2 blades off of the GM fan to see if it would keep up during the warmer months. I would like to hear if someone has done this. Those GM fans are high dollar to be hacking up.
          • Towers21
            • Oct 2012
            • 63
            Again, in these applications are you guys using a shroud or just leaving it open?
            • ric78
              • Feb 2013
              • 48
              We run a good shroud, fan half in half out pretty tight circle. Also we have the nose ducted in to direct air straight to the radiator. It has 2 sides and a a piece that bolts to the bottom of the nose and curves up to the top of the radiator.
              • RCJ
                • Nov 2007
                • 509
                Tight shroud , just get it close on the in and out.
                • zeroracing
                  • 1014
                  Took a four blade and cut it down, cut the front blades so it had like a gusset over it. Balanced with a lawn mower blade balancer. With no shroud on an open motor it only had issues on hammer down races. Most nights fine, with a good shroud I don't anticipate many issues on any night.
                  • Kwoods25
                    • Jul 2014
                    • 455
                    He had shroud and air ducts to rad
                    • Lizardracing
                      • 839
                      I have two of them off a stock passenger truck if any one if interested.
