2014 Gen-X slick set up
  • Cranky
    • Sep 2014
    • 174
    I have a 2014 Gen-X that I cannot get hooked up on a smooth slick track. Does anyone have a base slick set up that I can compare to? Car just seems to not have side bite or forward drive. Any help is appreciated.
  • SaddleUpLock&Load
    • Apr 2009
    • 203
    450-300 1in stagg
    175-225 4 1/2 stag
    300 5th
    remove dummy shock
    increase drop to 13 1/4
    j-bar 8 3/4 frame then down on pinion 1/2 inch
    Top right rod down two holes from neutral
    • Cranky
      • Sep 2014
      • 174
      Gen-X
      Wow....remove the dummy shock??!! I do have that on now and only have about 11 3/4" to 12" drop. I also have a 500lb on the LF, I also run a 16" LR 175 but all other springs the same.
        Your biggest issue is drop.
        • SaddleUpLock&Load
          • Apr 2009
          • 203
          Really only run the dummy when there's loads of traction and need to be bent up on the gas a lot. Really killed our forward drive in the slick.
          • mod88s
            • 226
            You talking about the LR shock in front?
            • Kromulous
              • 3008
              Yes mod88s.
              I have noticed a trend lately with that, run super high compression in the rear shock and then remove the "traction" shock. Genesis offers one with like 16 compression i think it is, have not ran it like this yet thou.
              I agree with MB racer too, more droop.
              Just say no...
              • cjsracing
                • 841
                13.5" minimum really? I was always told 13"
                  That is the standard answer. What you can really use depends on many factors.
                    I'll second some previous comments.
                    I wouldn't line up with less than 13" drop in the LR.
                    Outside of that, removing the "traction" shock from in front of the LR is the best traction you're going to find. It does require you to enter the corner a little different though as the car could have a tendency to sit down on you even if you do get some super high compression in your shock behind. Like most things, it's a trade off.
                    • cjsracing
                      • 841
                      Matt49
                      If the LRF shock was on a clamp bracket instead of the birdcage then you wouldn't be losing traction from the LRF shock correct? So you could still have it helping hold the car on entry but not robbing traction?
                        Matt49
                        Still a compromise. As soon as your pinion starts wrapping down from decel, that shock is pulling the car down.
                        • rakracing
                          • Dec 2014
                          • 218
                          anyone ever tried running the dummy shock on a clamp behind the rear as a dual shock to hold the car up but not take away traction,
                            It will take some traction away. Maybe, you could keep it from being g too bad.
                            Not legal these days, however...
                            • MBR Performance
                              • Nov 2014
                              • 199
                              On a Gen X with 13 1/2" of drop how much is that from ride height?
