33-36 rearend
  • sdhracing15
    • May 2016
    • 14
    33-36 rearend
    How can I make a 33 36 rearend work in a car that calls for a 33 35 without changing the axle tube
  • 7uptruckracer
    You can't.
    • Kromulous
      • 3008
      Put it in, the RR will just stick out an xtra inch. Just make sure its located via the J Bar in the proper location, laterally.
      Run a 6" offset rim on the RR, instead of 5".
      Not preferred of course.
      Just say no...
      • 7uptruckracer
        For the cost of the rim just put the tube and axle in it. Wouldn't take much time at all and its easy to do.
        • sdhracing15
          • May 2016
          • 14
          Thanks for the advise guys. I'm going from a tnt rocket type to a tnt mastersbilt type and I was just trying to save most of the stuff that I took off
          • rcp2908
            • 44
            Move the right front out an inch if you can
            • taylor2727
              • May 2013
              • 203
              U can pull tube out and cut an inch off
              • a25rjr
                • 3774
                Good point.....just use a standard wood cutting radial arm saw. Those blades work fine when cutting aluminum. A standard chop saw blade tends to melt the aluminum too much.
                Turn LEFT, Vote RIGHT!
                • fastford
                  • 4059
                  that's what I did, my axles had the adjusting bolts and lock nuts on the end of the axles, I took them off and got the inch with out cutting, only cut the tube.
                  • rakracing
                    • Dec 2014
                    • 218
                    maybe try running it, use a 6" off if its slick, there a lot of times I wish my grt had a 36" tube to free it up.
