I wanna put a metal cutting blade on my dewalt chop saw, but when I look them up, it says for steel only. Is there one for steel and aluminum? If so, what brand do yall use? The ones Im looking at are about $100 so I don't want to buy the wrong one.
Chop saw blade
steel blade should be fine to cut any metal, theres usually a stone or masonary or steel or ductile iron choices, I use the steel for everything except stone stuff, don't remember paying that much for blades though. are you using a fiber type wheel or a metal tooth type.
Im using a fiber(abrasive) now, but I want a metal one. What brand are you using?Originally posted by rakracing View Poststeel blade should be fine to cut any metal, theres usually a stone or masonary or steel or ductile iron choices, I use the steel for everything except stone stuff, don't remember paying that much for blades though. are you using a fiber type wheel or a metal tooth type.Turn LEFT, Vote RIGHT!
I always used the fibers weather for my chop saw or gas saw, use a diamond wheel for concrete, ive seen the ones with teeth but never used, I think you need low rpm and cooling for them. I do have a fire rescue blade for my gas saw that we'll pretty much cut anything
If you are cutting steel with a tooth blade you need to clamp it very tight so it doesn't move because if it does you knock the carbide tips off. For cutting aluminum get a60 or 80 tooth carbide blade and it'll work just fine.
Yes, if you use a high speed saw like a miter saw. If you look on the blade it will tell you max rpm. If its for a chop saw it will have to be a lo-speed blade.Originally posted by Krooser View PostCan you cut steel with a hi-speed steel blade? I thought those were for low speed cold saws...
Im gonna try the Evolution Rage blade for my chop saw. Its a good multi-purpose blade inc wood.Turn LEFT, Vote RIGHT!
You don't like evolutions blades?Originally posted by stock car driveryou need a different saw
Ive used a evolution rage saw for about 8 years now.
I use a oshlun 80 tooth blade 67 bucks on ebay.
Whats different about their blades, everyone online said you have to buy an adapter?Turn LEFT, Vote RIGHT!
I went with the beileigh 225M cold saw. It's not as fast cutting as the dewalt chop saw's we used in the past, but the cut ends are true and allow for final assembly with minimal cleanup. Not to mention there is a LOT less dust and debris in the air.
Like others have said if you are planning on getting away from the abrasive cutting blades you will need a low speed high torque saw.
