Progressive spring on Rt Ft.
  • HMS27
    • May 2011
    • 57
    First things first. Rules don't allow stacked springs of adjustable shocks. (Going back old school with this class)
    We can run a snubber with the chain on left rear but no shock in front.
    My question is has anyone tried a progressive rate on the right front and would it preform like a stacked spring?
    07 black front rocket.
    If your not racing on dirt it's your on asphalt!
    A true progressive will not perform like a two stage. That is 2 different spring rates. A progressive continues to get stiffer. A progressive would be like a bumpstop setup.
    You could get a single spring wound to be like a dual rate by one of the manufacturers, like PAC.
    • HMS27
      • May 2011
      • 57
      Ok, thanks
