Soft RF and no drive
  • Dirtmod13
    • Jan 2014
    • 245
    Any help with soft rf spring and how to gain back drive
  • Dirtmod13
    • Jan 2014
    • 245
    Car was great with 50lb. heavier spring
    • zeroracing
      • 1014
      Then why not put the heavier spring back in it?
      • Dirtmod13
        • Jan 2014
        • 245
        Cuz that is what the big chassis mnfgr's are saying for new setups. Didn't do much. Had a very dry track and wondering how the super low rate rf can help drive. I get it that it helps front dive into corner and rotating it down and lifting left rear up to make it easier to get on the bars. But overall was not tighter.
        • zeroracing
          • 1014
          How low did you go? On a bump or stack or just spring?
          • Punisher88
            • Nov 2014
            • 495
            A dual stage could get the turn in plus the traction leaving I believe.
            • DEKconsulting
              • Apr 2015
              • 234
              If it was just as good in and better off then just stick with it chassis mnfers setups r a starting point and adjust from there. U dont have to run that just cause josh richards runs a 275 rf or jd running a duall stage rf u have to run what u like causr lets face it most of us dobt drive like jd or josh.
              • DEKconsulting
                • Apr 2015
                • 234
                • fastford
                  • 4059
                  may be dek, BUT, if you don't try and keep up, you fall behind. You cant just throw a soft spring on without understanding the whole picture. sounds to me like dirtmod just put a soft spring on without the rest of the ingredients and lost left rear drive.
                  • Kromulous
                    • 3008
                    We much prefer a stack.
                    Never tried the soft RF with rubbers, but wouldn't mind looking into it.
                    Just say no...
                    • DEKconsulting
                      • Apr 2015
                      • 234
                      I wasn't meaning to not try to get faster ford I was just meaning that because it works for this guy's doesn't mean it'll work for him . Yes I totally agree u just can't trow a soft right front and expect it to be a cure all it is like u said the big picture of everything working together
                      • dirtslinger4
                        • Jun 2011
                        • 53
                        just remember every action has a reaction. Sometimes its important to always return to the basics
                        • dirtracerl77
                          • 89
                          When I was running a soft rf, I also had to run a softer rr to keep it from picking the lr off the ground and loosing the drive.
                          • Dirtmod13
                            • Jan 2014
                            • 245
                            That's kind of what I was thinking. Couple pics show rf way down. Could be adding more rr wheel weight due to it. What was the softer rr rate you used? Like 25 lbs less or?
                              To know how to fix a problem, we must first understand what the problem is.
                              Changing to a softer RF hurts forward bite off of the corner because it lowers dynamic wedge. So by changing to a softer RF spring and changing nothing else, you've tipped the scales in the direction of the RR tire (dynamically, not on the scales in the shop) which will cause the RR to start driving harder than it used to and the LR will not drive as hard as it used to. This is a loss of forward bite because the car wants to continue turning when you get on the gas (driving off the RR) rather than straighten back out (driving off the LR).
                              So if the problem is that we've lost dynamic wedge, then the obvious solution is to make another change that will give us back the dynamic wedge we lost. There are many ways to do that and some have negative side affects on other parts of the corner. So then you'll have to potentially make another adjustment to account for that.
                              As previously stated, the soft RF setup isn't as simple as putting a softer RF spring on. There may be 4 or 5 other changes you need to make to get that car balanced again.
                              The true benefit to the super soft RF deal is car attitude for aero downforce. This cannot be overstated so it can certainly be worth dialing in a setup like this.
                              Yes you can put a 400 on the RF and the car will drive off the corner great but your nose will be 10 inches off the ground and the LR decking won't be up in the air. These things provide grip and grip provides speed.
